One of the clients reported acdwgfilterimp16.exe error - it occurs when AutoCAD LT is closed. Error window appears several times in one Win session. Update2 was installed, than LT was reinstalled, all folders and registry entries were deleted before the second installation. Nothing helps - user still gets this error. It has no impact on his work, i.e. LT is not crashing or hanging.
Do you know what acdwgfilterimp16.exe is used for? I searched a bit on Autodesk discussion groups and google, there was a suggestion that it's listed in the Programs > Startup folder, but there are no shortcuts related to AutoCAD in that folder.
File path: C:\Program Files\Common Files\Autodesk Shared\AcDwgFilter
Thanks in advance for your suggestions.
Edited by: Mariuszzz on Oct 14, 2008 1:46 PM
