Only if your LT version will let you explode it first with -EXPORTTOAUTOCAD command (then you will need to recreate the block of course, and then it will no longer be a proxy).
...nor as smart I suspect...
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
The drawing.
The entities that have been exploded will loose all thier reason for being a block.
Ergo: Dumb lines; not Smart blocks
It ain't personal
I could be a tin can for all we know about one another.
