AutoCAD LT Forum
XREF drawings - Dimensions Styles
2 REPLIES 2
518 Views, 2 Replies
We use Annotative dimensions in our drawings.  Every time we xref a drawing or cut and paste a drawing, it brings in all the Annotation scales of the other drawing.  Purging does not get rid of these scales and sometimes there gets to be a lot of them.
Changing the Annotation scale prior to dimensioning an object can be a LONG and tedious procedure when these get quite numerous.
Is there any way to either stop the annotative scales from being imported, or a way to delete them?
2 REPLIES 2
Scalelistedit is the only variable that I can see that you can delete them, but having to reset this all the time is quite annoying.
Charles_Shade
There is a Scale List Cleanup Utility here for '08 and '09 versions:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334440&linkID=9240818
I believe this has been fixed with the '10 and newer versions
You need to get all your files, even block only files.
”Boost
