AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Writing a plug-in to work with Autocad LT 2011
4 REPLIES 4
johnniesiliz
453 Views, 4 Replies
Does anybody have experience with writing a plug-in with visual basic?  Is there a specific version of visual that works with Autocad LT 2011?  Or will express 2012 work too?
4 REPLIES 4
dgorsman
in reply to: johnniesiliz
LT doesn't support plug-ins or other programmatic extensions.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
hwalker
in reply to: dgorsman
I don't know if it's changed it LT 2011 or not, BUT in LT 2009 you can have an external vb program run in Autocad.
I have one which draws steel shapes for me.
I have a text box called txtbSWid which has the following done to it everytime my program loads up
txtbSWId.LinkMode = 0                                  '0 = reset
txtbSWId.LinkTopic = "AutoCAD LT.DDE|system"           'establish DDE link
txtbSWId.LinkMode = 2
The below is all the information I get from my program which draws a single polyline. en$ is the variable for the enter key
swibeam$ = "_ortho" + en$ + "off" + en$
swibeam$ = swibeam$ + "_pline" + en$ + "none" + en$ + "0" + en$ ', True 'draw pline begining @ last point
swibeam$ = swibeam$ + "@" + SWIwidthx$ + "<0" + en$
swibeam$ = swibeam$ + "@" + SWIStartToe$ + "<270" + en$
swibeam$ = swibeam$ + "Arc" + en$ + "@" + SWiToeChord$ + "<227.5" + en$
swibeam$ = swibeam$ + "Line" + en$ + "@" + SWITotalFlange$ + "<185" + en$
swibeam$ = swibeam$ + "Arc" + en$ + "@" + SWiRootChord$ + "<227.5" + en$
swibeam$ = swibeam$ + "Line" + en$ + "@" + SWIdmtrx$ + "<270" + en$
swibeam$ = swibeam$ + "Arc" + en$ + "@" + SWiRootChord$ + "<312.5" + en$
swibeam$ = swibeam$ + "Line" + en$ + "@" + SWITotalFlange$ + "<355" + en$
swibeam$ = swibeam$ + "Arc" + en$ + "@" + SWiToeChord$ + "<312.5" + en$
swibeam$ = swibeam$ + "Line" + en$ + "@" + SWIStartToe$ + "<270" + en$
swibeam$ = swibeam$ + "@" + SWIwidthx$ + "<180" + en$
swibeam$ = swibeam$ + "close" + en$
After it has collected all that data the following line is run
txtbSWId.LinkExecute swibeam$ + "move last  0,0 "
The line below just ends the program completely
Unload SWI
To run my program in Autocad I have a button with the following command in it
^C^C_ai_startapp myprogram.exe
Howard Walker
Left Handed and Proud
pendean
in reply to: hwalker
Question: does your VB program run more than once in an LT2009 session?
hwalker
in reply to: pendean
Not too sure what you mean, but if you mean after it's drawn one polyline and shutdown can I immediately run it again to draw another. The answer is yes
Howard Walker
”Boost
