AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Wipeouts Created in LT2004 a problem in LT2000
2 REPLIES 2
203 Views, 2 Replies
I work in LT2004 but my boss works in another office and has only LT2000 . . . so I have to save my work in LT2000.
The problem is all my wipeout frames, which I turned off, show up in his version . . . and he says he has no "wipeout" command with which to turn them back off again.
Is there a fix to this?
2 REPLIES 2
Charles_Shade
The boss needs to either move up or learn to live with it or you need to stop using them perhaps?
drjohn
... OR you can use a solid and assign  it color 255.
You won't be able to turn off frame but it may work for you.
Caveat:  Some PDF writers plot that as solid black so if, for example, you use a solid to be behind text you may not see the text.
FWIW
HTH
DJ
”Boost
