I work in LT2004 but my boss works in another office and has only LT2000 . . . so I have to save my work in LT2000.
The problem is all my wipeout frames, which I turned off, show up in his version . . . and he says he has no "wipeout" command with which to turn them back off again.
Is there a fix to this?
The boss needs to either move up or learn to live with it or you need to stop using them perhaps?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
... OR you can use a solid and assign it color 255.
You won't be able to turn off frame but it may work for you.
Caveat: Some PDF writers plot that as solid black so if, for example, you use a solid to be behind text you may not see the text.
FWIW
HTH
DJ
