Hi!
I don't really know how to explain my issue and hence can't search for solutions but let me explain what I am battling with.
I don't know how it happened but somehow while I was drawing some lock function must have turned on.
I am in model space and have a floor plan consisting of many different layers. I can select any line from any layer drawn and it becomes highlighted, but it all shows up as being part of one layer i,e 5 even if it was drawn as layer 2. If I select a line (that shows as layer 5, I try chnage its color, its linetype - it shows it has chnaged in the property toolbar, but in reality in model space it remains unchanged.
If I select an object first and then say try and move it, 'm' & enter - it uselects and I get that square box whith a popup message, select objects. If I do so and enter, I can the move the object.
In the layer property tab - nothing is on lock or freeze or off. I can switch between layers but then as before everything I select on the drawing shows up as this new layer.
What did I press and how can I go back to normal?!
Thanks IN ADVANCE!
fEIGE
Solved by pendean. Go to Solution.
