Digital Signatures identify file ownership, nothing more.
A DS in AutoCAD can be removed by simply exporting to DXF, and then opening
and saving that back to a DWG file.
To assign a DS (actually, a Digital ID) to a file, or files, you need to be
outside AutoCAD/LT and use the Attach Digital Signatures program LT
installed. You can also use SECURITYOPTIONS command inside LT.
To get a Digital ID(certificate), you need to buy one; VeriSign and others
offer that: these are not custom made for apps like AutoCAD, these sellers
do not care or cater for specific programs, these are standalone features of
electronic files and file exchanges you add to each PC user.
So, in a nutshell, you need to talk to VeriSign or whomever about costs,
procedures for recipients to receive and verify your signatures, test
in-house because you will need to walk all of your recipients through it as
well.
Oh, don't forget to turn off SIGWARN variable (and your recipient needs to
do the same) if you want to avoid a lot of pup-ups.
Dean Saadallah
http://LTisACAD.blogspot.com
