Solved by Amito. Go to Solution.
@Amito wrote:
You can try to type 'lwdefault' in the command line put this value to 0 (zero). If i'm ok this will solve your problem.
This is the best solution, but also note that you will not see the thickness of your lines in modelspace either, it's a global on/off switch.
Also if you look at the row of icons at the bottom left of the Autocad Window The fourth from the right should be Show/Hide Lineweight. That is a toggle as well. If it's blue your lineweights will show, if it's grey they won't
Howard Walker
