I installed a second version od AutoCad 2014 LT on my home computer to work during the snow storm.
When I opened the files from work, the unit measurements were off by a huge order of magnitute....(basically squared)
So, for example, the dimension string that I knew was 25'0" was measuring 640'-0"
It is a project being done in Metric, but regardless, the scale was off by a rediculous amount.
Anyone know why my new installation would be off by this much? and how to fix it?
I didn't change anything, and opened the file directly. No insertions or anything else changed.
It was the first file I opened with the new installation of CAD.
All of the other files associated with the same project did the same thing.
However another file from a separate project did not.
Check your units settings, looks like an inches to millimetres automatic scaling. Type in the DWGUNITS command, if you have the civil object enabler installed. It will tell you the actual units AutoCAD believes the drawing is in. We have had this problem on almost every new installation. Check the locality (country) and units setting are correct during installation, rather than blindly hitting enter everytime the installer asks you if these are correct. As Dean said, turn that **** annotative scaling off, unless you can ensure all drawings are set at the correct scale and using the correct units.
