AutoCAD LT General
Active Contributor
ABielecki
Message 11 of 12 (107 Views)
Re: Unhandled Exception E0434F4D
02-07-2013 03:45 AM in reply to: WESMCKENZIE3499
Hello.
I'm not sure that I understand you correctly.
I get  this communicate when I work in AutoCAD LT 2010 on windows XP.
I've installed .NET Framework 3.5.
I've reinstall all software and frameworks also.
But this problem is still exist.
What shall I do now?
GIS
Charles_Shade
Message 12 of 12 (101 Views)
02-07-2013 04:27 AM in reply to: ABielecki
Since one of the posts speaks to removing all instances of .NET and reinstalling those you may need to follow this advice:
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
And to ensure a clean install of AutoCAD:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
You are not logged in.
Ask the Community
