Hello.
I'm not sure that I understand you correctly.
I get this communicate when I work in AutoCAD LT 2010 on windows XP.
I've installed .NET Framework 3.5.
I've reinstall all software and frameworks also.
But this problem is still exist.
What shall I do now?
Since one of the posts speaks to removing all instances of .NET and reinstalling those you may need to follow this advice:
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
And to ensure a clean install of AutoCAD:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
