setvar;grips;$M=$(if,$(eq,$(getvar,grips),0),1,0)
Rough translation:
If getvar,grips equals 0 then setvar,grips to 1 else 0
Conny
skrev i meddelandet news:5066413@discussion.autodesk.com...
I am trying to transfer the few customized toolbars, & menus our company
uses from LT '02 to LT '06. I noticed we had a button that was supposed to
turn toggle the grips on & off, however it only manages to bring up the
"grips" command at the command line & you have to input "1" or "0" & "enter"
to change the current setting. Is there some sort of "getvar" or other
language I can use for the "Macro" portion of Properties in the CUI to have
a single button toggle the setting or will I need to make one button to turn
them on & one to tun them off to avoid using the keyboard?
Scott
