I finally got my custom toolbar transferred from Autocad LT 2004. I copied the bmp icon files to the icons folder under Users>>Support>Icons and added this path to the support paths under the options command. However the icons still show up as clouds with a ? mark. What do I have to do to get the correct icons, which were custom made in Autocad 2002 LT, to show up in Autocad LT 2013?
Did you replace the main menu, or edit it, or did you load this as an added exrra menu?
Does CUI command let you actually reselect your custom icon for any of tge Toolbar'a buttons?
