Is there a short cout to getting to the source drawing file containing block data? Drilling down into the Program Files folder is tedious in the heat of getting drawings done. Thanks.
Solved by mrdavie. Go to Solution.
Design Center
Tool Palettes - Right click the Block and see what options are there
Create dropdown Menu or a Ribbon of Macros with your most oft used Blocks.
Though I sense a contradiction in your Thread title and your stated need.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Never mind. I just noticed the three dots at the end of the path for the source file. Clicking on it takes me to the appropriate folder.
