Is there a way to find out what is in a subscription download before you download it?
Like what changes have been made to the program
thanks
Solved by camilo.lemos. Go to Solution.
I believe Gordon is referring to new releases available through the Subscription Center?
If so, you can typically compare current and previous versions on the specific product page, under the features tab (see example below).
I have the subscription with autocad LT 2013
when I go to the subscription center there is a download that says autocad lt 2013 that is 756 mb
it does not say anything else
I would like to know if this is an update or a the program seems very small to be the whole program but large just to be an update.
If it is an update I would like to know what it is updating before installing 756mb
So I have not been able to find anywhere what is in the downloads on the subscription center page
like autodesk has on there other update pages, they always tell you exactly what you are downloading.
thanks
Hi NorthsideDesign,
AutoCAD LT is not a very big program. The 756mb download you can see in the Subscription Center is the full version, not just an updated.
Best regards,
