AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Set Registry Key from Script
2 REPLIES 2
389 Views, 2 Replies
I'd be really gratefull if someone could help me with this please. I need to change the following registry key programmatically and add it as part of a script routine:
HKEY_CURRENT_USER\Software\PlotSoft\Writer\PDF_ROTATECROP\Rotate_Degree and set it to a value of 10e as a Hexadecimal.
I have attempted this using the setenv command but cannot get the setting to take - this is the script I'm using:
setenv
10e
I've tried all sorts of various configurations of this but can't get the variable to change.
Would anyone have any ideas?
Many thanks in advance.
2 REPLIES 2
pendean
SETENV will not do that I believe.
steven-g
AFAIK you cannot change the location that autocad uses to store the value you create with setenv. I would personally look into using a windows VBSscript to do something like that especially as it looks to be accessing values from another program anyway.
”Boost
