I have been running AutoCAD LT2002 on a very old desktop computer and am attempting to switch to my new laptop. I have the original CD, Serial No., and CD Key. I have switched computers many times in the past and have had no problems installing this software on any of them. This time, it is giving me a "serial number not valid" message and will not let me proceed with the installation. I had some difficulty entering the number initially (the label with the s.n. was quite faded, but I KNOW that the serial number is entered correctly now-- what do I do?
Thanks in advance on any help you can provide!
Hi Dean,
Thanks so much for taking the time to suggest the installation section of the board. Unfortunately, the 2002LT version is so old that I can't find anything pertaining to its installation. Unlike newer versions which are web-based, mine is a standalone license.
What confuses me is that I am assuming that the procedure for installing is that when I type in the s.n. and CD key, the program goes to the installation CD and to see if my input matches what is encrypted on the CD. If it has worked repeatedly in the past, it should work now. As I mentioned, I know for certain that I am entering the correct s.n.
Any additional help would be most appreciated. I have two projects I need to get completed and need to transfer work to the new laptop.
I have same problem with same product with same s.o.. I work fully offline, and I'm SURE that s.n. is correct. Is there any phone number o email to contact to solve this problem ????
I'm actually locked out work !
