AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Selection Woes
2 REPLIES 2
ablanchard
355 Views, 2 Replies
Selection Woes
When I select a block for editing (move, copy, rotate), there is a considerable lag before the block is selected.
It doesn't matter if it is a pick or a crossing/window.
I don't have the lag when picking polylines, lines or circles.
It doesn't happen when I pick the command first, but I don't want to abandon noun/verb selection.
What could be causing this?
I am running LT 2014.
2 REPLIES 2
pendean
in reply to: ablanchard
Is your INFER button selected (bottom left of the AutoCAD program window)?
Does this happen in all your files or just this one?
What's different today on your PC or network from the last time this worked better?
ablanchard
Although I didn't see the "Infer" button, I looked it up in Help and it mentioned Geometric Constraints.
I don't use Geometric Constraints, but I went ahead and picked the "Delete Constraints" and I haven't had the problem since.
I thought it was only this file but I was able to duplicate it on a new drawing. I drew 2 rectangles and blocked one. As soon as I selected the block, I got the delay.
As for difference between then and now, I have no idea.
But thanks, if it happens again I will let you know with a little more details (hopefully).
”Boost
