AutoCAD LT Forum
Scaling objects in x or y only
5 REPLIES 5
risdo
266 Views, 5 Replies
Is there any way to scale an object (or group of objects) in x or y only, without having to make them into blocks first?
If not, this would seem to be a major omission on Autodesk's part...
5 REPLIES 5
in reply to: risdo
Block only, it's the only entity type that could scale in only one
direction.
Are you perhaps wanting something else in the other entity types?
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
risdo
in reply to: risdo
I'm not sure I understand the question.
in reply to: risdo
What else do you want to scale in an X or Y direction?
Dean Saadallah
risdo
in reply to: risdo
Arcs and polylines.
in reply to: risdo
There would be no X or Y only scaling in those entities, that's the problem.
Scale is not the correct tool.
You seek LENGTHEN command or STRETCH or EXTEND, or something else.
Dean Saadallah
”Boost
