Im trying out Autocad LT after many years of using Autocad. I want to define what I can and cannot do. One item I'm trying to convert to LT is to insert a block into a drawing, have it come in on the right layer and the right scale and allow for user input of rotation. I've done that, works great. What I'd like to add is this:
If I'm on layer x, and the macro inserts the new symbol on layer y, return after to the previous layer x without user input. I was able to do this in Autocad using (SETQ LAYR (GETVAR "CLAYER")) and then returning to the layer with -LAYER;S;!LAYR;;
Is there a work around for LT?
Yes I know. However there is sometimes a work around with Deisel and I'm hoping someone here might know.
Fingers crossed, it's handy for some blocks to stay on the current layer.
^C^C_change \ properties la psdim
I don't know if this will help but here is a macro that I put on a template button that changes an object to a layer called psdim with a single pick. If you have lots of layers, it would take lots of buttons.
Lowell
When I first looked at this I thought, "This isn't what I want at all." Than I looked again...and realized this is exactly what I want and why the heck I didnt think of this. So simple.
That fixes the last issue I had with transitioning my menu's to LT. Thank you very much.
