AutoCAD LT General
Message 1 of 3 (367 Views)
Rotating In The Z-Axis
367 Views, 2 Replies
03-13-2001 09:48 PM
I have an object that I would like to rotate 90 degrees in the Z axis. Is this possible in AutoCAD LT98? How can I do so?
*Rudolph, Dietmar
Message 2 of 3 (367 Views)
Re: Rotating In The Z-Axis
03-13-2001 11:29 PM in reply to: DStrood
AutoCAD LT will always rotate around the current Z axis. The trick is
to use the UCS command and place the Z axis in such a way that you get
the rotation you want.
Dietmar Rudolph
President, CR/LF GmbH, http://www.crlf.de
Vice-President Europe, CADLock, Inc. http://www.cadlock.com
Member of the Autodesk Discussion Forum Moderator Program
Author, "Mastering AutoCAD 2000 Objects", http://www.crlf.de/Verlag/PublishingServices.html
*St, Buckle
Message 3 of 3 (367 Views)
03-14-2001 10:03 AM in reply to: DStrood
Rotate the UCS about the X axis 90o first. Then use rotate.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
