PROPERTIES command can help, if you want them all to rotate to the same
angle.
OR you can do it the long way using Rotate command, and each block picked
one at a time: LT is just not that flexible to save you time.
You can take a small bite out of it by having a simple little continuous
running toolbar button macro, with content like (assuming here you want to
rotate everything 45 degrees from where it is, and around the INSertion
point of the entity). Substitute or change anything as applicable to your
needs:
*^C^C_rotate;_single;\ins;\45
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
