AutoCAD LT General
New Member
jodaddy101
Message 1 of 6 (523 Views)
Relative Angle
523 Views, 5 Replies
09-28-2005 10:05 AM
I would like to draw a series of line segments where the angle of each is known relative to the angle of the last line segment. I expected the "Polar Angle measurement, Relative to last segment" to do this but I can't make it work. I'm left with mentally accumulating the angles as I draw the segments.
Can anyone tell me what I'm doing wrong and how to do what I want?
Jim Thompson
*Dean Saadallah
Message 2 of 6 (523 Views)
Re: Relative Angle
09-28-2005 10:26 AM in reply to: jodaddy101
If you want to use POLAR Angle, right-click over the word
POLAR at the bottom of your LT screen, select Settings, make
sure Polar tracking is selected, set the angle to the
smallest you would possible need (5, 10, 25, 45, or 1...),
make sure "track using polar angle settings" and "Relative
to last Segment" are selected on the pop-up.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
New Member
jodaddy101
Message 3 of 6 (523 Views)
Re: Relative Angle
09-28-2005 01:20 PM in reply to: jodaddy101
Following your directions:
The angles I wanted, each referenced to the preceding line segment angle, were: 45, -30, 60, 75, -90, and 120. Using the smallest, 30 degrees didn't do much for the angles not a multiple of 30 degrees. I used the least divisor of these angles, 15 degrees, and that worked better than what I was doing.
I had hoped to simply enter on the command line, assuming all line lengths of 5, the following:
@5<45
@5<-30
@5<60
@5<75
@5<-90
@5<120
This would have been far simpler than finding the least divisor of all and using that.
Am I still missing something?
Jim Thompson
P.S. Thanks for the speedy reply.
*Dean Saadallah
Message 4 of 6 (523 Views)
Re: Relative Angle
09-28-2005 01:41 PM in reply to: jodaddy101
Perhaps you should see what your DYNPICOORDS is set to,
relative is what it needs to be. Also look up DYNPIFORMAT,
DYNPIVIS and DYNMODE variables. Initial settings may be all
you need.
Dean Saadallah
Valued Contributor
cadking2k5
Message 5 of 6 (148 Views)
Re: Relative Angle
12-06-2013 08:48 PM in reply to: *Dean Saadallah
I have created a command and trying to get Autodesk to buy it it draws lines and the relative to last segment is 0 (not 180)and you can change the direction of the angles clock or counter clock so you do not have to do all that math
*Expert Elite*
pendean
Message 6 of 6 (143 Views)
Re: Relative Angle
12-07-2013 05:05 AM in reply to: jodaddy101
Autodesk Exchange Apps Store is open to 3rd party vendors selling quality add-ons for autodesk products: try it. They do test and validate all apps first so be prepared.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Announcements
Need installation help?
Ask the Community
