Okay, I have a few dozen variables that I am trying to store for use at the command line. I can only append to input area with the actual quickcalc open, anyone know how i can reinitialize the global variable list?
Well, from the command line, you can call forth the command line version of the calculator using 'cal right after a command has been started. AutoCAD has built in variables such as "mee" which, as an expression, is equal to [(end+end)/2];. I have expressions which are quite lengthy, such as [(xof(nea+nea)/2+yof(nea))]; and I would like to create a variable like "mee" that I can call forth right from the command line. Say I wanted to call it "xnny", I can do that in CAD's GUI for the calculator, but it doesn't seem to stick when I try to call it from the command line after 'cal.
I know the command line calculator is dead, but I mean what's the point of technical design if you're not getting techincal.
Any help would be greatly appreciated. Thanks.
NO NO NO, global variables. I am posting this because I have already tried everything mentioned. I'm a CAD Manager for cryin out loud lol. What I am looking to set are global variables (as mentioned in the FIRST post); maybe LT doesn't allow you to do it since LT doesn't support LISP. See the attached picture; you can use the 'Sample variables' from the command line. I would like to get my custom variables, i.e. 'mxxy' to operate the same way the 'Sample variables' do.
(yes, i know you're wondering how I could be a CAD manager and use LT. It's not my company and i cant get them to upgrade)
Am I being dense here (don't even think about answering that), what exactly did you mean by saying reinitialising the list, because from a later post I now read that, as actually creating a custom value and not being able to use that value later from within the 'cal command. And I just did that, well a very simple named constant.
How do you enter the global variable now, at the commandline?
In the palette window?
The former is your LT customization answer.
I discovered it totally random only a couple months ago, so I'm still learning but it's extremely useful. It's really useful for electrical and mechanical layouts since they are generally more representative than literal. If you're working with another consultant's file and the snaps are all messed up, it can be difficult to align a supply grille over a window and offset it 6" or so. You can write a quick ((end+end)/2+[6,0]), place it in the right click menu and fly as your laying out those registers. Only problem with that is not all draftsmen have the same right click setup so I need to be able to set these to the command line so we can all use the same expressions.
The sample variables, I am able to enter into the command line as you see them spelled out in the palette. I posted pics to show an example of what I am trying to do. I'm new to discussion boards, guess I should have started with the pics. Basically, you will see that I started my line command, fired up the command line calculator, entered the entire expression, and continued with the line command. I want the expression (xof(nea+nea)/2+yof(nea)) to be a neat 3 or 4 letter variable similar to what was seen in the last pic of the quickcalc palette. I have dozens more, but that one is pretty easy to follow.
The constant is a fixed point in the coordinate system. It needs to vary. Man what a doozy, the command line calculator really is dead.
Good call, it works for me, and to be honest is probably an even quicker method because you can combine it with the line command and go straight into picking points. And the answer to Q2 is yes, I can create a macro that starts a line using the 'cal sequence from post 13.
This isn't about calling macros from the command line. AutoCAD has shortened names for built-in expressions, such as 'mee'. I want to take the macro expressions we have and give them shortened names too so that I can run those expressions right from the command line calculator. If I want a line between two points, I can type " LINE;'cal;mee; " and CAD will ask me to select two endpoints whose [x,y] values are passed to the expression, divided in half, and the LINE command resumes from the output of the calculation. This is what I am trying to do. Right now we have them in shortcut menus and toolbars, but everyone has a different style for how they want stuff laid out. Command line shortcuts would be way easier.
Is what I've been saying this whole time clearer now?
Blast, I thought for sure you could since you can add your own in the calculator palette. Oh well, I guess that just about does it for me then. I'll have to get my company to switch to the full version (ya right).
