AutoCAD LT General
Active Contributor
KristinLindberg
Message 1 of 12 (1,983 Views)
Quick way to rename layout tabs?
1983 Views, 11 Replies
10-18-2012 12:07 PM
So, I have this drawing with over 200 layout tabs. (I do shop drawings for a cabinet/countertop manufacturer, and we do one drawing per project.) Here's the thing... I need to eliminate pages 1, 6, 14, 20, 24, 30, 40, 44, 47, 56, 61, 64, 73, 78, 81, 90, 95, and 101 because they are now NOT a part of the project.
Here's why that is a problem:
In my title block, I  have the layout name as a field, so it says "PG [layout tab name]/224" which is needed because there's a table of contents for the pages that are printed.
Is there any easy eay to renumber all the tabs, or am I stuck re-numbering every single one?
AutoCAD Mechanical 2013 SP2
AutoCAD 2013 SP2
pendean
Message 2 of 12 (1,979 Views)
Re: Quick way to rename layout tabs?
10-18-2012 12:14 PM in reply to: KristinLindberg
There is no automatic way in LT.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Distinguished Contributor
marchitect_nc
Message 3 of 12 (1,972 Views)
10-18-2012 01:00 PM in reply to: KristinLindberg
Will this work...Rename the unneeded tabs to Not Used-1, Not Used-6, etc, delete the viewports from those layouts,and now your Title Block shows the Table of Contents with layouts as Not Used-1, etc?
Just an idea.
m
Active Contributor
KristinLindberg
Message 4 of 12 (1,967 Views)
10-18-2012 01:18 PM in reply to: KristinLindberg
Unfortunately I think that would confuse the workers down in the shop even more.
AutoCAD 2013 SP2
Active Contributor
KristinLindberg
Message 5 of 12 (1,966 Views)
10-18-2012 01:19 PM in reply to: pendean
Is there an automatic way with AutoCAD (full version)? I have AutoCAD at home (not student version - we had the scary plot stamp stuck in our office for awhile from a temp worker on a laptop - YIKES). Maybe I could open it into AutoCAD and save and then open it back up in LT. Any suggestions there?
AutoCAD 2013 SP2
pendean
Message 6 of 12 (1,959 Views)
10-18-2012 02:28 PM in reply to: KristinLindberg
If you have access to AutOCAD, you can post in the Customization Discussion area for an automation customization:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Your original post, repeated there, would be plenty of info to share (with the screenshot).
Valued Mentor
steven-g
Message 7 of 12 (1,938 Views)
10-18-2012 10:58 PM in reply to: KristinLindberg
The layout command will allow you to rename a tab layout, so a simple script would do the job, in windows notepad create a simple command matrix as follows
layout r 1 1
layout r 2 2
layout r 3 scratch
layout r 4 3
layout r 5 4
layout r 6 scratch1
layout r 7 5
layout r 8 6
layout r 9 scratch2
layout r 10 7
this gives you a logical view of which layouts need to alter ,the first 2 layouts in the example are fine (the "r" is for rename)
then split this matrix up into individual lines as shown below, make sure there are no spaces anywhere even at the end of a line (the very last line should be a blank line).
script-----
layout
r
3
scratch
layout
r
4
3
layout
r
5
4
layout
r
6
scratch1
layout
r
7
5
layout
r
8
6
layout
r
9
scratch2
layout
r
10
7
script-----
Save the file with an extension scr ("Rename.scr"). Look in the help files for how to run a script in autocad, but you can just drag it onto the autocad window from windows explorer. In the example I started with tabs 1-10 and finished with 1-7 plus 3 tabs called scratch* then just delete the scratch files. Create a test drawing with 10 tabs to try it and whenever you run a script like this I would advise doing it on a copy of a file just in case of errors.
Regards Steven Gray
Setting Out (Joinery Manufacturing)
Autocad 2013LT
Windows 7 professional
pendean
Message 8 of 12 (1,926 Views)
10-19-2012 06:00 AM in reply to: steven-g
I'm all for autoamtion when it saves time, but for a one-off and at over 99 layouts to delete and rename, it would probably be quicker to manually do so that wrting a script out in full like that IMHO.
Right-click a layout, delete.
Double-click a layout, type in new name.
So much quicker for a one-off 99 layout renaming and deletion project.
Either way, if you are going to suggest a fix, go all the way and not partial to only suit your needs. The OP wishes to delete as well as rename, so the script would be more accurately represented like this:
layout
delete
1
layout
rename
2
1
layout
rename
3
2
layout
rename
4
3
layout
rename
5
4
layout
delete
6
layout
rename
7
5
and so on all the way to layout number 99.
Active Contributor
KristinLindberg
Message 9 of 12 (1,917 Views)
10-19-2012 07:15 AM in reply to: pendean
Can't believe I forgot about the layout command... what was I (not) thinking?!
AutoCAD 2013 SP2
Valued Mentor
steven-g
Message 10 of 12 (1,893 Views)
10-19-2012 01:50 PM in reply to: pendean
Either way, if you are going to suggest a fix, go all the way and not partial to only suit your needs. and what would my needs be.:catvery-happy:
I was under the impression the discussion groups were to encourage discussion and give people assistance in finding solutions. It's very easy to say it can't be done and then later come back and say I can do it better when someone else offers a suggestion. I will humbly admit to an oversight on my part for completely missing the delete option, but I was concentrating on the rename part of the question. And indeed I could have gone the whole way and written the whole script and posted it here, but my intention was to show a method that exists and works. And as a matter of fact and not opinion It actually took me just under 2 minutes to complete the script for 201 tabs, I use excel to automate scripts regularly, If it was something that the OP does regularly, and has excel, that could be reduce down to one excel cell to hold the number of tabs in a drawing then a list of the tab numbers to be removed. (rough guess for the example given 20 seconds)
Regards Steven Gray
Autocad 2013LT
You are not logged in.
Ask the Community
