AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Publish - Error did not plot
3 REPLIES 3
peter.jones123
7940 Views, 3 Replies
On choosing to publish 3 Autocad drawing files, all of which can be plotted individually, one file and others if I choose a larger selection, does not plot.
The "Device name" is missing on the resultant error list after the publish job has completed.
hope_this_helps
3 REPLIES 3
pendean
in reply to: peter.jones123
PUBLISH requires a pagesetup to be selected to be used: did you assign one?
peter.jones123
in reply to: pendean
Yes, a fresh page set up on every page. Also I installed a local printer and renewed the page setup to avoid the risk of networks.
hope_this_helps
pendean
Import and test that pagesetup in each file's PLOT command, and see if you can more easily identify the issue.
”Boost
