Properties box is really long (horizontally). (see attachment)
When I select an object, then right mouse and pick "Properties" the box containing the different things to change is so long it runs off my screen and goes into my 2nd monitor.
Any way to fix this?
Solved by Charles_Shade. Go to Solution.
Go over the the Second monitor, hover the Mouse over the Right edge until you see the left-rght arrow and drag.
Save your workspace.
Most all dialog boxes can be resized in this way.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Set LOCKUI to 0.
Does that allow you to change the Dialog box size?
Height, Width, you're one of theose guys who does not like Length aren't you?
Autohide only works of your cursor moves away from it completely: why not also dock it left or right as well and see if that helps (found in the same right-click menu as Autohide).
