AutoCAD LT General
Member
slayer5608
Message 1 of 5 (234 Views)
Problems with dimensions changing
234 Views, 4 Replies
07-19-2012 07:09 AM
Hello, I am currently updating company drawings from one template to another. I am using the copy and paste method. What I am noticing is that when I copy the part and the dimension from the origninal drawing ( all in 3 place dimensioning) to the new template Autocad is changing the dimensions to 4 place dimensions. First question is why is this happening and second question is can it be stopped? Thank you to everyone in advanced that takes the time to read and respond.
hwalker
Message 2 of 5 (226 Views)
Re: Problems with dimensions changing
07-19-2012 07:25 AM in reply to: slayer5608
Click on 'Format'
Click on 'Units'
Change the precision there to 0.000 at the moment it is on 0.0000
Valued Mentor
Message 3 of 5 (225 Views)
07-19-2012 07:26 AM in reply to: slayer5608
Hi, are you talking about the precision of the measurement? If so you can change the dimstyle to show 3 places rather than 4.
Member
slayer5608
Message 4 of 5 (219 Views)
07-19-2012 07:35 AM in reply to: hwalker
So am I correct in the thought that when you copy and paste autocad will force the dimension precision to what ever the new locations default is?
Valued Mentor
Message 5 of 5 (215 Views)
07-19-2012 07:44 AM in reply to: slayer5608
Yes and no. In this case if the dimstyle in the new drawing has the same name as the old drawing, it will use the setting of the new drawing. If the new drawing does not have the same dimstyle it will import the dimstyle from the old drawing
You are not logged in.
Ask the Community
