AutoCAD LT Forum
Problem with dimension using mouse in Autocad LT 2012
19 REPLIES 19
Message 1 of 20
465 Views, 19 Replies
I am new in AutoCad . While dimensioning, it poped a window and I selected "distance' and right clicked and entered. The dimension goes away. Is it problem with my mouse or I did not follow the right step. I would appreciate if anyone could guide me.
19 REPLIES 19
Message 2 of 20
Charles_Shade
Explain in a little more detail.
DISTANCE and Dimensioning are two different things.
Also the type of dimension you want is critical: Linear, Aligned, Angular, etc.
You may want to read up a little about Dimensioning in AutoCAD:
http://exchange.autodesk.com/autocadlt/enu/online-help/search#WS1a9193826455f5ffa23ce210c4a30acaf-4c...
Which Command do you wish to execute?
Message 3 of 20
in reply to: Charles_Shade
Thank you Charles for your help.
I used AutoCd Lt 2004. After long time I came to the new version 2012. I am still a beginner.
First I drew a line. I selected liner dimension, selected two ends. It showed line dimension on a drawn line in a shaded form. There is a option to select diatance. I selected distance and entered. I tried enter by right clicking  the mouse. I tried with 'enter" from key board. When I put enter the dimension vanishes. After that I could not get any dimension.
Is it mouse problem or I forgot all I learnt in AutoCad. I would highly apporeciate if you could help me on this.
Thank you.
Robby
Message 4 of 20
Charles_Shade
All you should need to do is pick both ends of your line and then pick where you want the dimension line to be; all with the mouse. Left click the mouse to complete the command.
From there you may want to run DIMCONTINUE.
There should not be an additional step to choose Distance.
Please mark any response as "Accept as Solution" if it answers your question.
Kudos + gladly accepted if you are feeling magnanimous
_____________________________________________________________
Message 5 of 20
Thank you  Charles,
I choose two points and the dimenstion appered in the centre. I then left clicked to accept.  It is still in the dimension command. It is not going out. How can I discontinue dimcontinue?
I am close. I would appreciate if you could help me.
Thanks.
Robby
Message 6 of 20
pendean
What command are you using to dimension?
Message 7 of 20
heinsite
in reply to: pendean
It sounds a lot like he's using DIMCONTINUE to me...
Dave
Dave Hein, P.E.
Message 8 of 20
Charles_Shade
Make sure you are using DIMLINEAR
If you drag the mouse around after you have clicked the two end points (don't Left click yet) does the Dimension line move with it?
Left Click normally invokes an <Enter> in AutoCAD
Message 9 of 20
Charles,
Dimension does not move at all after showing fixed dimension on the centre of the line. If I click left mouse + sign of dimensuion comes where ever I click.  When I go to draw another line, the dimension vanishes.  I  had put the comand dimlinear below in command box below as well.
Please help.
Robby
Message 10 of 20
Charles_Shade
Post your drawing file that is giving you problem.
Message 11 of 20
pendean
Again, what command are you using to dimension? If you don't know, say so and give an idea on what you are clicking on.
Message 12 of 20
Charles,
Please find the attached file.
We just bought AutoCad 2012 a week back. I could not find any direct technical support from Autodesk from internet . Is there a way I can talk to the AtoCAD tech support personnel and try different options while on line. It looks like it is realted to either my software setup or problem with my mouse. ( It is a new computer with new Dell mouse).
I would appreciate if you could help me on this one.
Regards
Robby
Message 13 of 20
pendean
Your file dimensions just fine, see attached: I used DIMALIGNED command with your angles.
Autodesk support is now on Twitter 24/5 (@autodeskcare): http://autode.sk/sbGrpx
Up & Ready Installation and Startup Help (free for new installs):
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2786107&linkID=9240817
Safety Net / Per Incident Autodesk support (not free):
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=15892664&linkID=9240817
If you are on subscription, visit your Autodesk
Subscription Page for direct Autodesk Help:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2915212&linkID=9240817
Customer Error Reporting:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7047344&linkID=9240817
Different options that are available for self-help
technical support from Autodesk Product Support
E-Services:
http://www.youtube.com/watch?v=Ylj0o-R_Zn0
Message 14 of 20
Dean,
Thank you.
Yes it worked with dimaligned. Great!   I am able to put angle on it.
Next thing , If I would like snap in the middle of a line, I do not know how to do it.
I tried to go and learn from tutorials and I could not find the basics. I am  a new learner although I took 1 week training and  used AutoCad Lt eight years back for few months. May be I forgot it with time.
I would appreciate if you could help me on my above concern.
Robby
Message 15 of 20
Charles_Shade
Message 16 of 20
pendean
Look up DIMALIGNED and DIMLINEAR commands.
MID is a snap selection option you can use while in a command to select the MIDpoint of a line: while in a command, hold the shift-key down and right-click to get a pop-up menu with all of your options.
Message 17 of 20
Dean,
I found how to dimension angle. Thank for the great help.
I just want to draw a line by snapping in the middle of  a line. I do not know  what command to put in order to snap and draw a line.
Robby
Message 18 of 20
Thank you Dean and Charles for bearing with me.
It is a great help from both of you.
I will ask help on the group if I have more problem.
I like it because it  is the best way of learing tool.
Robby
Message 19 of 20
Charles_Shade
OSMODE is a place to start as well as Running Objects Snaps.
Message 20 of 20
pendean
The top video today at this link is about dimensioning tips, explore it and the other videos on offer too:
http://www.cadalyst.com/video
There are online tutorials from Autodesk worth exploring:
http://usa.autodesk.com/autocad-lt/training/
And even more in youtube:
http://www.youtube.com/results?search_query=AutoCAD+LT+video+tutorials
All for free: start exploring (and don't worry too much about versions listed, they still apply).
”Boost
