Help,
i have autocad lt 11 (64 bits) on a laptop lenovo W530 (nvidia K2000M). I use Unigraphics NX6 too.
I have 2 problems since i migrated to Windows 7 entreprise 64 bits. I haven't this problem with Windows XP.
1- When i do a chamfer or a raccord (at 0) The shift key freeze the screen and it's impossible to obtain the result.
For example the shift key doesn't work when i deselect an object from a group.
2- I have another problem when i type a command or a text the response time is not immediate.
Thanks for your answer
regards
Sylvain
The version is fully updated and patched.
My commandeline is doked.
And i change the dynmode value and it's not good
The problem still occur. For information in the office 3 personns change this configuration (laptop + win7) and at the moment all have the same problem. So we have 2 screens in configuration extend and a keyboard extern. And I have the same problem with the both. But not shift key problem with other soft.
Hello, is there anybody could help me? I'm searching on internet and i don't find anywhere the same problem
i test different adjustment and nothing change....
Your last post speaks of 2 screens being used. Assuming the other LT Seats are also on Laptops with the video being pushed to a second monitor as well.
How much RAM for the Laptops? Aero or other themes being used?
Have you tried not using the second monitor and just having LT run on the Laptop screen only?
If so do the problems persist?
If not then there is an issue with the second monitor, and that may be nothing more than adding the monitor and then extending LT to that screen.
Changing OS from Win XP to Win 7 would not automatically make video changes to the setup of LT from one OS to another.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Assuming the other LT Seats are also on Laptops with the video being pushed to a second monitor as well. It's OK
How much RAM for the Laptops? 8GB
Aero or other themes being used? Basic themes
Have you tried not using the second monitor and just having LT run on the Laptop screen only? yes I have
If so do the problems persist? The problems persist
So, i tested the sticky modification. And nothing changed but it seems it's the good way. I do a mistake. I launch the "on-screen-keyboard" after that my "physical keyboard" did'nt work. I tested this config with autocad and it works!
To change the keybord situation i must tell to my IT crew (because i don't have the administrator right). That was not easy but after some times. We find one thing. When my laptop was configured it was using the soft "dameware virtual keyboard" and it's the reason why i can't change the config keyboard alone.
We try to delete this soft (try because for the moment it's not complete) and between a restart my physical keyboard and the shift key was ok. Autocad works very good.
BUT when the IT connect my laptop again, the problem be back and some parts of the soft "dameware virtual keyboard" was'nt destroy.
Now i'm waiting the next week because they will try to delete completely this soft. and i hope autocad works.
Maybe it's not the solution, so if you have an idea don't hesitate. Tell me
Finally after different test ( it's not easy to launch a safe mode in Windows 7 entreprise with a lenovo W530) I try in safe mode and Autocad did not work. I launch Autocad and after 5 seconds it closes.
But I have a news about my problem. I found a dwg file made 03 may 2013 (with autocad lt11 / windows XP) and when i launch Autocad by this file, this file unblock all my problems! ! Incredible!
After this i can use Autocad normally create a new drawing etc... For information this file was create by the same gabarit (.dwt) file.
I check if i found some difference between the both situation and i saw the old file is a trusted dwg and not the new one. How it could be possible? And is this, the reason why i have problems or not? I don't know.
Maybe when my IT install Autocad an option must be valid?
if you have any answer tell me because it's very weird.
Yes it works but it's not the right way.
I hope really someone gives me a solution. I'm an autocad teacher in my entreprise and i can't explain the .dwt file if it doesn't work. And how explain to start Autocad, don't use the icon but use one specific dwg file. it doesn't make any sense.
It's the first thing i do. I made a new template from the old trusted file. and it doesn't work.
I used the default autocad template too and it doesn't work.
Why Autocad doesn't open a trusted Autocad file like an untrusted Autocad file? And sometimes not. that is the question...
