My layout is 11x17 and within the printable area displayed. Page setup is 11x17, Landscape But my layout gets cut off when Publishing to PDF. But is OK when Plotting PDF. I found an earlier post talking about PDF scaling having to be set to None. I found a scale setting in my CutePDF Writer that is set to 100%. There is not a None selection.
Another interesting observation is that Publishing will print the sheet upright. Plotting prints the layout rotated -90.
I am using Publish to print multiple layouts to one file.
Solved by Charles_Shade. Go to Solution.
Have you tried using the built in DWG to PDF driver instead of the CutePDF driver?
How about looking in CutePDF to make sure the osftware is set to Landscape or Potrait as needed?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Didn't work for me. I run Autocad 2017 LT. My layouts have frame lines in the plottable area (layout is set to print in a real life printer).
Ploting to printer or ploting to PDF one by one is fine. But publishing all the layouts makes the printable area smaller or offsets it a bit so the the frame lines don't print properly. I've used DWG to PDF and Autocad pdf presents. no differents.
Any ideas?
