Show only
Search instead for
I'm working on a schematic and am trying to create polylines to make it easier to trace circuits throughout the drawing. I have one or two spots on the drawing like the attached photo where I need to create one polyline. Is it even possible to create a breakout like this and have all the lines joined to make one line?
Try here: http://discussion.autodesk.com/forums/thread.jspa?messageID=6299899
Search this forum for more possible options to your query not sure about Midpoint or Intersection joining though; probably would need segments between each horizontal in your pirture. You will most likely need to complete a few steps to get your desired results.
Regards, Charles Shade
No, plines only join at end points. Create what you have drawn as a group or
a scalable 'smart' Dynamic Block, or consider upgrading to AutoCAD
Electrical which I believe does what you want as part of the program's
features.
Hey there,
Sorry for the late reply but you could just use solid lines and apply a tight Background Mask on the mtext from the properties menu.
Then just use the texttofront command
