Hi.
Just installed the AutoCAD LT. I am trying to set up the drawing layers such that they are permanent evertime I open the program and begin a new drawing. How do I set this up?
Chris
@kobilancm wrote:Hi.
Chris
A template is prolly what you need.
Open a new dwg, place all the items you want on it such as titleblock or whatever, create layers/linetypes/dimstyles ... etc ... etc .... SAVE AS A DWT file in your templates dir as a unique filename.
Now when you open a new drawing use the new template that you just created and start from there. All layers/linetypes/dimstyles/text styles will be available in the new drawing.
Helpful hint #243:
If you open an older drawing that was not created using this template you can open another drawing simultaneously and using the Design Center you can drag and drop these new layers and such into the current drawing.
HTH
DJ
QNEW and STARTUP Variables
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
