Hi there,
I'm trying to create a script for a kind of automatic page set up update...
With this new 2013 LT version the behaviour of the psetupin has change in the way that you cannot simply overwrite a page set up anymore, not without confirming the overwrite, so my question is:
Is there a command or a way to delete ALL existing page set up ?
Thanks.
I do not know of a way to delete all existing page setups but thought I would bump this since the new Forum setup is holding it in the Give Solutions queue.
There are some Lisp routines I believe but alas we are not able to use those. Right click each and delete seems to be the way to go.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
It seems that, either because of the new forum or because of the spam attacks, all previous answers were deleted...
There were also about 50 orphaned questions that was discovered around 4 months ago that were in an AutoCAD LT Forum that was just existing in the ether. Yours may have been one of them.
Was there a solution for you?
Can you just move the unwanted page setups to another folder. That's what we do in our office. We move the annoying default AutoCAD ones to a folder called unused, and put the ones we actually want and use in the default folder. Sorry if I'm a bit vague and not directly answering your scripting question. . Just making suggestions.
Scott Hodges
