"kevinmcfarland" <kpm@friar.com>What
wrote in message
href="news:f054082.0@WebX.maYIadrTaRb">news:f054082.0@WebX.maYIadrTaRb...
works great for us is to simply select the objects in ACLT copyclip them and
then Open Illustrator and Paste them in. But you have to have both programs on
the same computer. (Maybe if you have a network liscence or something). Maybe
you can copyclip out of a .dwg viewer like Volo view (i don't know).
The objects go into illustrator as a "group" and the AutoCAD background
shows up too. In Illustrator the objects can be ungrouped and the background
deleted. The objects keep their color from AutoCAD so anything that's white
will have to be changed. Then the lines have a very minimal thickness so that
will have to be changed too, in order to print.
If scale is an issue, we draw a rectabgle in AutoCAD that is 1"X1" to scale
(i.e. 96x96 @ 1/8"=1"-0"). Then in Illustrator I scale that rectangle up to
1"X1"
Not much help if you can't get both programs on the same machine. But
definately saves time over exporting, importing, and then cleaning up.
If you can export to a hi-res pdf (Acrobat Writer) Illustrator can open
those files.
Hope this helps,
Kevin
"mp45" <I
href="mailto:mp45@georgetown.edu">mp45@georgetown.edu> wrote in message
href="news:f054082.2@WebX.maYIadrTaRb">news:f054082.2@WebX.maYIadrTaRb...
don't have access to adobe illustrator right now. Once I do have access, I
will then have to learn it. It seems that AutoCad LT2000 doesn't convert all
that easily or all that accurately into adobe anyhow. I'm not opposed to
learning new programs, but time is becoming an issue. Does anyone know of a
company that can take my autocad files and plot them onto a transparency at
5080dpi? I've done some web searches, and scoped out other CAD sites, but am
not coming up with much.
