I am a new AutoCAD user and need some help. I have created .dwg drawings in AutoCAD LT 2013 and have found that people with older versions of AutoCAD cannot open them. Is there a generic overall version of AutoCAD that I can save my drawings in that would be accessible to all versions of AutoCAD? Thanks for your help and guidance!
When you go to save your drawing you have the option of which version to save it to. If you aren't sure what the other people have then a safe bet is to use v2000. Just do a "save as" and look at the bottom of the dialogue box where you see the version listed, hit the arrow on the right and your choices will be there.
Also in OPTIONS under the Open and Save tab you can set this to the defualt you want.
You may run into PrOxy Objects in the newer version not saving or playing well in previous versions if you do need to go back to 2000. (MLeaders are a good example.)
PROXYGRAPHICS, PROXYNOTICE, PROXYSHOW Variable should all be explored for each vesion of AutoCAD being used.
Items listed in CAPS are typically Commands in AutoCAD
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Better yet, keep your drawings in 2013 and send them the link (politely) to the free DWG viewer located on the autodesk home page and let them convert it themselves.
Let me know how well that goes for you 'cause I've not found out how to make others do that yet.
Thanks to all for your input. I have saved my .dwg file in the 2000 version of AutoCAD and will be sharing them with others shortly. From my initial testing with a few internal folks it appears this is my best option. I appreciate all the input and will update in the next few weeks with how it works.
I don't really give them an option 🙂 If they can work in autocad, they can handle converting the file. I work in 2010, but if someone gives me a 2013 file i just convertit myself. You know, give a man a fish he'll eat for a day... kind of thing.
