AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Open Dialog Box Slow to Come Up
1 REPLY 1
1623 Views, 1 Reply
This started afted we moved to a new windows workgroup name and accessing files on new server.  We are drive mapped to resources.  File - Open and Open Shortcut commands cause AutoCad 2008 LT to momentary hang before the Open Dialog Box appears.  All Workstations are affected.  Once a file is selected, however, it runs normally and loads quickly.  Just it takes a long time, some machines 45 secs, to get the Open box up. Have already disabled Digital Signature Icons with no improvement.
Tags (3)
1 REPLY 1
pendean
That normally means WIndows and/or AutoCAD are both searching through dead links or folders before resolving the issues and proceeding with the command at hand: nothing to fix inside AutoCAD except to eliminate any links or paths to the older server in OPTIONS command's FILES tab listings.
Are any other commands also slow? I'm thinking XREF, ADCENTER and others too, all impacted by your new server naming conventions.
”Boost
