AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Oops, I'm back in paper space!
2 REPLIES 2
381 Views, 2 Replies
Ok, I'm bopping along adding dimensions and other annotations inside a viewport. Suddenly I find that I have placed some annotation in paper space because the program jumped from inside the viewport to outside the viewport. What is happening to cause this. Am I staring at the screen too intently? Am I moving my mouse too quickly? Does zooming cause this?
2 REPLIES 2
nestly2
It shouldn't switch to PSpace on it's own, could you be double-clicking outside of the viewports(s)?
An easy way to tell when it happens is while in PaperSpace, change the VP Color of your Dimension layer to a color you'd never use for dimensions. Now when a Dim is placed in PSpace, you'll notice it immediately.
Bob_Zurunkle
in reply to: nestly2
Excellent tip, Nestly! I can attest to the same behavior happening on my install of AutoCAD 2013, and I suspect it is tied to zooming inside a locked viewport...
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
”Boost
