AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Online menus grayed out in LT 2013
10 REPLIES 10
Message 1 of 11
brian.gatensby
759 Views, 10 Replies
The Online menus are grayed out on my installation of Autocad LT 2013 . How do I activate these ??
10 REPLIES 10
Message 2 of 11
pendean
in reply to: brian.gatensby
OPTIONS command's ONLINE tab, sign in.
or did you mean something else?
Message 3 of 11
brian.gatensby
in reply to: pendean
There is no ONLINE tab in OPTIONS !  Sign in to 360 is succesful on startup.
Do I need a subscription to access ONLINE features within LT ?
Message 4 of 11
Hmm... (LT 2013 OPTIONS dialog)
Message 5 of 11
Message 6 of 11
Hmm...
SP 1.1 installed?
Don't know if this has anything to do with it but thought I's ask.
Message 7 of 11
Yes SP1.1 is installed. I have tried a Windows "repair" of the install but that did not change anything. My next step will be complete uninstall/re-install.
Message 8 of 11
Message 9 of 11
Did you migrate setttings when you installed 2013?
Kate Morrical
Digital Design Manager, Washington DC
BIMmuse.com
Message 10 of 11
Volker_C
Before you do a complete uninstall/reinstall, verify that 360 was installed first. Assuming that you are using Windows 7:
In Control Panel ->> Programs and Feautures, select AutoCAD LT 2013.
Select Uninstall/Change
Select, Add or Remove Features
Under Feature the check box for "Autodesk 360 for AutoCAD" should be selected. If it is not, then select it and select Update.
Cheers,
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
Message 11 of 11
Volker_C
Hi, were you able to resolve this problem?
Cheers,
Volker
Volker C.
”Boost
