Hi, we are having a problem here at our office. this revolves around one file. When I open the file, some objects (text, hatch, lines - all different layers) disappear. This happens before any command is made, and the object that disappear are on layers that are active and not frozen on all viewports. Also, the rest of the objects on the layer are visable. Other objects on these layers are visable, and the objects that disappeared are not visable on the model space or paper space. On top of that, when someone else opens the file, different objects turn invisable, and they can see the things I cant. The drawing takes about 5+ mins to load, dispite it being not a very large file. I tried purging unused items, reconciling layers, unhiding everything, freezing and unfreezing all layers and restarting autocad.
Coincidentaly the x-ref dwg is having a very similar issue.
Thanks.
Have you tried to open the files with RECOVER rather than just OPEN?
Start with the XREF and recover it, then recover the top file, save both and then try to rebuild your drawing.
FWIW
DJ
Remove the XREF and then WBLOCK all content into a new File perhaps?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hello
An other idea ...
Do you know if your "bad" XREF has beem created / edited by a AutoCAD CIVIL, Architectural, MEP, Mechanical, etc ...
Because with theses special AutoCADs you can get specific objects/entities and have some strange problems with Proxy Entities !?
Bye, Pat
Patrice BRAUD
