Hello everyone
I'm having trouble getting a new command to work,
I would like to be able to type the command into the command line to make it work, but I don't know if I've missed something because it won't work, just comes up with "unknown command"
The only way I can make it work is via the tool bar were I've put a button for it, but tool bar drafting is too slow
The same happens if I modify a macro, it only works via the button
I'm using LT2010 on a Windows7 with all the bells and whistles turned off
I do not believe that you can modify a core Command of the program.
Nor add a core Command as this seems to be what you are asking.
I am interested in learning if a Macro can be called from the Command line or is that nothing more than a Script?
In one case I have modified the dimlinear Command to do certain things thru a Macro when invoked from a button. It would be interesting to give this a unique name and call it from the Command line.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
If you want to type the name of a custom command, you need full AutoCAD and learn to create LISP/ARX files.
CUI command only deals with menu/Ribbon/toolbar selections. That's it, that's it's sole function in AutoCAD and LT.
If you want to really learn obscure letter combos, the Windows feature of calling menubar commands by typing CTRL then the defined letter of a pulldown followed by the defined letter of a macro (and if you bury it, yet another letter) works in LT. But that's never caught on, gets old quickly, and any letter duplication forces you to come up with unusual selections:
http://msdn.microsoft.com/en-us/library/windows/desktop/ms647553(v=vs.85).aspx#keyboard_access
Thanks for your time Charles and Dean, it would be great if the command line was connected to the cui...I'm going to do more research on this. I'll see if I can find the file that the command line looks at
If i'm not mistaking I think you'll find it under your document and settings, something like this:
C:\Documents and Settings\adkr\Application Data\Autodesk\AutoCAD LT 2012 - English\R17\enu\Support
The file your looking for I suspect is "Commands.ATC"
If it helped please let me know.
I'm generally OK going in and changing Registry Settings and the like but I'm none too sure I would muck with that file.
Got any steps to follow to go with that advice?
The regular one, make a backup first... 😛
Other then that, none
commands.atc is an XML file, you would be risking a lot trying to edit it manually.It's a pointer for the ACTPCATALOGRES.DLL file, something else you should never manually edit either.
Neither file update with any user input or changes in the CUI, they only contain core commands OOTB.
CUI changes and edits are stored in the CUIx file, and it's "backup" the MNR extension file with the same name as the CUIx file.
And none of this does anything for the OP's primary wish.
