I have the latest and greatest, AutoCAD LT 2012 Windows 7 Ultimate 64-bit with all SPs installed, and an i7 with lots of memory and drive space, but I just started crashing when I select the Output tab. the rest of AutoCAD works fine. This started a week ago with LT 2011 and installing the latest 2012 yesterday didn't help any.
I can't print or convert to pdf or any other output method I try.
Edited by
Discussion_Admin
Try reloading a backup or previous CUI if there is something wrong in the Output Ribbon tab.
Did you changed the Tab in the 2011 install and then migrated this to the 2012?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
