I am having an issue where on one of our workstations the multi-sheet file "type" option is somehow being overidden when we try to publish to pdf. In Publish/Batch Plot under "General DWF/PDF options" it says Multi-sheet file but then when we hit publish it makes individual pdf files in the location folder. This requires an extra step to combine all these files in Acrobat. Does anyone have an idea what is negating this setting? I do not know how to troubleshoot it because it seems so straight forward.
Solved by Charles_Shade. Go to Solution.
Thank you all for your help. I've given up on trying to make this work. I'll just print to a multi-page DWF and then convert that to a PDF.
Thanks again
