AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Move/Copy PROPERTIES Button to Home Panel
1 REPLY 1
FLHX
344 Views, 1 Reply
I'd like to locate the PROPERTIES button in the Home Panel instead of, or in addition to, the View Panel.  When I go into CUI, it won't let me move/copy it.
1 REPLY 1
pendean
in reply to: FLHX
You want to copy just the button, or the whole panel that Properties resides on? CUI will let you do both, if you have read-write access to the CUIx file.
For the command only move, Grab it from the COMMAND LIST and drag it to the Home Panel you want to park it on.
”Boost
