AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Mouse left click selecting multiple lines,objects not working
6 REPLIES 6
beksolar
8496 Views, 6 Replies
Can not click on multiple objects or lines for erase,trim or extend commands. Is there a mode that I have turned on by accident , driver warning also comes up in trim offset command.
6 REPLIES 6
heinsite
in reply to: beksolar
Check that PICKADD = 1 and see if that makes a difference.
Dave.
Dave Hein, P.E.
beksolar
in reply to: heinsite
Thanks Dave that did it.
Charles_Shade
So that others may more readily find this solution to a similar query:
Please mark any response as "Accept as Solution" if it answers your question.
Kudos + gladly accepted if you are feeling magnanimous
_____________________________________________________________
Hi Charles,
I've had both PICKADD AND PICKFIRST change settings on me for no reason. Is this something that is fixed with SP1?
We are waiting for our IT Dept. to "have time" to install it. Smiley Wink We are using 2012LT.
Thanks for any info.
No there is nothing that I know off that will change these at random; though anecdotally it does happen.
Do you have any Custom Macros that you use for choosing items in a specific way?
No, I pretty much leave things alone other than the pgp file. I never had any problem with it untill we upgraded from 2011 to 2012. Since then it has happened twice with PICKADD  and once with PICKFIRST. All I can say is that I would have gone nuts if it wasn't for this forum. I don't know if I would have figured it out yet.
”Boost
