>>I can't reply directly to you (info@NOSPAMpendean.com doesn't allow me to
reply to you), so I must contact you this way.<<
You're not supposed to unless asked, as this is shared peer support and we
are all here to help each other out and share the knowledge and answers. My
time here is free for all and sometimes helpful, my time on my direct Email
is not free.
What DIESEL function are you looking for? All you are asking for so far is a
simple menu macro with no DIESEL programming.
A search of the LT discussion areas would reveal a few options, including
adding quotes around the full path of the file name and location to get it
to recognize. See if this helps:
^C^C_-insert;"C:/myfolder/MYBLOCK"
Dean Saadallah
http://www.pendean.com
LT Express Utilities
http://www.pendean.com/ltexpress
Expanded Links Pages
http://www.pendean.com/lt/links.htm
"Matt Batchelder" wrote in message
news:836A4227397267A77F18B27E661DB95A@in.WebX.maYIadrTaRb...
> Dean Saadallah,
> I don't want to scale or rotate the block when it's inserted, just want to
> pick a point in space and drop the block in.
> What I'm after is the exact syntax for the "insert block" DIESEL function.
> I need to tell the program where to find where I am storing my blocks. In
> other words, I don't know where or how to specify a search path within
this
