Trying to migrate my copy of AcadLT 2010 from and XP to Win7. I have successfully moved my menu customization, but do not have the custom settings for point mode/size and leaders that I had set. What file(s) am I looking to move to get this done?
NHAnimator
Solved by Charles_Shade. Go to Solution.
PDMODE and PDSIZE Variables need to be set in the new version for the Point Command.
As far as Leaders go if you open an existing Drawing that information should be there.
Copy and Paste it to a Palette or into the Template (which should have it) as needed.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thanks much for the help - it pointed me in the right direction. My leaders, templates and such were being set by a custom script I developed a while back. For some reason, Win7 was slightly changed one of the font names (tt0246m.ttf became tt0246m_0.ttf) when it was installed on the new system. That was stopping the script from completing before the custom leaders were defined. Modified the script to reflect the new names and all is golden.
NHAnimator
