AutoCAD LT Forum
Mask an area in paper space and cover with something else.
4 REPLIES 4
Cronk1
690 Views, 4 Replies
I want to mask/cover something in paper space and put something else instead.
Can I mask an area and then have something else there that shows?
Or perhaps use a viewport that covers what it is over on paper space?
4 REPLIES 4
drjohn
in reply to: Cronk1
As long as everything is in PS sure ... just place a wipeout over the un-needed object  and place the new object on top of that.
Others will argue about a color 255 hatch rather than wipeout, but whatever you choose it should work.
Be aware of DRAWORDER.
DJ
Cronk1
in reply to: drjohn
It worked. I got the draw order to work. But when I printed, the thing I "wiped out" printed??????
Cronk1
in reply to: Cronk1
I think I got it to work (though I am not sure what I did).
drjohn
in reply to: Cronk1
After you do a DRAWORDER you need to regen to see what it did. DRAWORDER does not always do what it is saying it does, A bit temperamental .... heavy on the mental. Sometimes send to back doesn't work so you have to select it with a PLACE BELOW ... or PLACE ABOVE or whatever. Regards, DJ
”Boost
