AutoCAD LT Forum
Macro for changing layers
7 REPLIES 7
Message 1 of 8
981 Views, 7 Replies
I'm working in AC 2014LT. I a getting refreshed with AC after being out of the game for 5 years.
I am looking to take a drawing with its own layers and cnahge them over to the layers I want them to be on. I realize they are some easy steps to do this, but I am doing it often and am attempting to build a button(macro) to do a bunch of steps in one click. My problem lays with trying to select one individual layer to change over to another layer.
I have the second part worked out. ^C^C(the part I need);_CHPROPS; layer;(new layer name);
I can get the objects to change over using the second part of this macro. I need to be able to tell ac to pick layer 2 and change props to dims, then pick layer 4 and change it to weld and so on.
I have hit the wall for now, and am looking for a spark to ignite me through to the next part.
Thank you
7 REPLIES 7
Message 2 of 8
rkmcswain
Does LT 2014 contain the LAYTRANS command? I know earlier versions did not, but they do keep adding functionality each year.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 8
in reply to: rkmcswain
Unless its name has changed, there is not a laytrans command.
Message 4 of 8
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
I have an ACAD LT 2012 on my current PC : NO LAYTRANS command !
I am almost sure that this command has not been added to ACAD LT 2013 or LT 2014 ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 5 of 8
pendean
LAYMRG command to merge one or many layers into another. Not available as a macro but way more efficient and accurate that CHPROP or much else in LT.
Message 6 of 8
I cant seem to get laymrg to work consistantly. I know its a user input error, but I have to figure out what it is that is making it not work more than 1 in 10 times.
Message 7 of 8
pendean
What exactly is the issue? Seems to work quite well here all the time.
Message 8 of 8
 PEBKAC. I am using laymrg exclusively now.
  PEBKAC ("Problem Exists Between Keyboard And Chair")
Thanks for the guidance.
”Boost
